    Dec 2009
    Hungary
    hi all,
    I'd like to merge a lot of different types clips into one big clip. I've got .wmv, mpg, mpeg, avi, etc. files.
    I've been trying for a couple days, but I still can't.
    With the video content: there is nothing problem. But the audio always delays.
    I'm using : Xilisoft Video Converter Ultimate. This is a perfect tool for converting.
    First I create H.264 mp4 files from the different types, and it's perfect. (none of the MP4 files' sound delay)
    When I try to merge the mp4 file, the audio delays. I've tried tons of program, but the result is always the same.
    What shall I do? Which program do I use? I'd like a program, that has batch function. (100 files into 1, for example)
    Thanks in advance, and sorry for my English.
    How do you merge the mp4? what software? I would try yamb 1.6(not latest beta)
    And you could instead try make avi xvid video with mp3 audio using xilisoft or free tools like WINFF! Then join the avi files.
    Dec 2009
    Hungary
    I merge with Boilsoft Video Joiner or I use Xilisoft Video converter.
    I've trid WINFF, but when I set the 'convert to' and 'device preset' settings, the program simple just disappear. I have to open it again, set them...but disappear again.
    I got Yamb too. I do it with it in this way:
    Editing / Click to join supported files / add some file / next / browse where I want to save it , than NEXT and...in a few sec, it displays: concatenation complete. I got one file from One source (not from all the sources), and it is 3gp, even though I set to MP4.
