I was using Vegas Pro 8. When exporting I would using specific settings for vimeo. The results gave me a nice 1280 by 720 video.
I decided to upgrade to Windows 7 and CS4. Getting used to using CS4 and have an issue getting a proper 1280 by 720 clip. It always exports with letter boxing. I don't see anywhere during the encoding portion that allows me to change this.
Here is a link to a video edited with Vegas
http://vimeo.com/7922053
Here is one edited in CS4
http://vimeo.com/8254907
While I export at 1280 by 720 in CS4 the video file shows up at the bottom download as 1280 by 980...I don't know why. Can someone help?
Smile
Smile -
Your link is dead.
Did you export with square pixels? Hit the output preview tab in AME in the left pane to see if there are no black borders before exporting. If there is, you have set something incorrectly.
If you still can't figure it out, provide more information like a screenshot of your settings, project settings, etc.. -
I fixed the link...
I think I figured it out. I used different settings this time around for output. I'm still not sure where the boxing settings are though.Smile
Smile
Adobe Premier CS4 playback issues + Hello
By Large_Pudding in forum Newbie / General discussionsReplies: 0Last Post: 4th Dec 2010, 19:22 -
Premier Pro CS4 Crashes during Export
By Don Man in forum EditingReplies: 9Last Post: 26th Jun 2010, 11:35 -
First Steps In Premier CS4
By Sundayarak in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2010, 19:09 -
Premier CS4 exporting issue
By Jonza in forum EditingReplies: 2Last Post: 3rd Feb 2010, 04:08 -
Problem with CS4 Premier Pro
By Devilish Me in forum EditingReplies: 4Last Post: 12th Mar 2009, 18:06
