no I want to add to it
Results 31 to 46 of 46
On a tangent, here's the VideoHelp index page from a search on the phrase "Recover DVD Data" IF the problem deals with a 'bad' or unreadable disk.
(This relates to Steve's question if Trollino wants to 'salvage' a disk's data.)
In my experience, recovering data is more often a disappointment than success. Sometimes I can recover many files but often not the largest ones. It's a very hit-or-miss proposition. -
no the disk is not finalized, I was burning a video onto it and the power to my burner went out, my computer can read half the video but then stops in the middle, it does not let me continue burning the video I began before, I believe that the disk is not finalized
why is it you refuse to belive you can NOT reuse a dvd-r
dvd-ram and DVD-RW yes.. but not dvd-r
even if you could force your burner to 'add to' the disc
the DVD player will not search that far out on the disc for the NEW session info
its NOT designed to do that -
trollino, forget the dvd then.
It is considered damaged so you need to salvage what you can and put what you have left on a new dvd.
You can try some of the recovery programs to see what you can lift off it.
Then put it all on another dvd.
DVDs are from ~.25 to $1...so it won't break you... -
I had a similar thing happen a while back, interested to know your take on it.
1) he power went out when i was burning using a vhs to dvd standalone.
2) when the power can back on it gave me the option to continue and found the content
3) i recorded the last bit on the disc
4) it finalised.
5) i still have the original tape
Question being, is it better to re-transfer this one? It plays fine and doesnt seem to have any problems.
Many thanks -
I would think a standalone would be a different situation but if the disc is important to you, by all means copy the disc, that is if there are no perceived problems during playback.
You can use one of the ripping softwares to get it to your hard drive, anydvd, dvdfab or dvddecrypter.
Then use ImgBurn to copy the file back to new disc. -
I've never seen a truly interrupted burn-process be restarted and deliver a usable disk. I'll be interested in hearing more specifics about the hardware that accomplishes this feat. Sounds like a great product - I mean, it should be completely do-able in our digital world, but I've never heard of success until this one comment.
Not a problem. The guys were working on the powerxobx across the road, I had spent time burning all that morning and was almost finished another disc whch was my last when the power shut off. I thought great, i guess this ones a coaster. When the power came back n in an hour I turned on the burner and a box popped up saying recover data (or something like that). I clicked it, it took about the same time as finalising a disc and said recovery complete.
It then showed the menu screen as normal, so i continued with the burn process on another scene. Both the first part of the video plays and then part after the power outage in the second thumbnail of scene selection. I had about 3 minutes left on the disc but had finished all content, finalised and it works.
The model is a Sansui SAN0712 DVD recorder. It does pretty good transfers for my home vhs movies only paid $25 for it too second hand. Done a good 60 discs so far, multiple backups and re-do's of special tapes etc. Good little unit. -
Yes, I agree..even windows explorer can copy it but rippers tend to be a safer way to copy video from a dvd disc.
Some dvd recorders introduce some errors while some don't.
My maggy 2160 always introduces some errors...perhaps they wouldn't be a factor but I generally just go ahead and use a decrypter/ripper.
I have about 6 dvd recorders laying around here...
DVD: Can You Add .SRT To A VIDEO_TS Folder/Files?
By SetoTitan in forum SubtitleReplies: 9Last Post: 6th Jan 2018, 07:30 -
add SRT to VIDEO_TS
By exekutive in forum MacReplies: 8Last Post: 4th Jul 2011, 13:49 -
add a video_ts project a mpeg file
By simor in forum Authoring (DVD)Replies: 2Last Post: 29th Nov 2010, 16:50 -
Question how to delete files that won't delete
By jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 14:09 -
THE BEST POSSIBLE WAY TO Convert RMVB TO AVI WITH VIRTUALLY NOTHING!!!
By RMVBMASTAPRO in forum Video ConversionReplies: 3Last Post: 26th May 2007, 03:07
