Happy holidays!
I have a Panasonic DMR-EH55 DVD recorder, hooked up to a Sony Bravia LCD TV. Is there a way to record the HD channels where the picture is full screen? I also have a Motorola cable box.
I can record the non HD channels and get the picture full screen. With the HD channels, the full screen (in 16 x 9 widescreen)ends up being recorded as a letter boxed picture.
I know the DMR-EH55 can't record a total HD picture. But, I was wondering if I can record more than a letter box picture with these HD channels.
Thanks for the info,
Marshall
HD is 16x9 by definition. When TV stations play 4x3 material upscaled to HD you get side bars.
Your Panasonic SD DVD recorder may or may not allow 16x9 recording. I have an LG DVD recorder that does record wide or 4x3.
If your Panasonic is locked to 4x3, HD material will be recorded letterbox and 4x3 SD material upscaled to HD will have black on all four sides.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Did you forget I already answered your question here?
http://www.avsforum.com/avs-vb/showthread.php?t=1210038
Your Motorola STB does not output wide screen over SD outputs. It's the STBs fault, not your EH-55. The EH-55 only records what it's sent. -
Thank you both for your answers. It's disappointing that the Motorola STB doesn't
output wide screen over SD outputs. I was hoping I wouldn't have to buy a
Component to S-Video converter.
It's still strange that the non-HD channels are recorded 16 X 9 full screen, while
the HD channels end up being recorded as letterboxed. Aaarrgh! -
I just click the Picture resize button on my Panasonic HDTV remote control to fill the screen.
I also use it when watching movies on the SYFI channel ... that are letter box ... it fills the screen nicely. -
I believe it's because most STB mfgs. assume anyone using the composite or S-video (SD outputs) have a 4:3 TV. If they were to send out WS not letterboxed a 4:3 TV would crop the sides. It's really a shame they don't all have a simple setting to allow WS over SD outputsOriginally Posted by Marshfish
They knew exactly what they were doing. They wanted you to upgrade to HD over analog component or HDMI.
Issue with Panasonic DVD-Recorder DMR-EH55
By chudbeagle69 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 9th Oct 2016, 14:47 -
Panasonic DMR-EH55 - help to make it region-free
By cyberspace in forum DVD & Blu-ray RecordersReplies: 5Last Post: 8th Oct 2009, 23:33 -
Panasonic DMR-EZ27 and EZ28 switches channels while recording
By dtsb52 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2009, 12:59 -
Panasonic DMR-EH55/57
By dvdpanrec in forum DVD & Blu-ray RecordersReplies: 19Last Post: 19th Dec 2007, 06:38 -
PANASONIC DMR EH55 EU firmware
By meringone in forum DVD & Blu-ray RecordersReplies: 4Last Post: 15th May 2007, 12:11
