Hi,
I got Adobe After Effects CS3 and a Sony HDR-Cx105 handycam that puts out video in the avchd format (.mts/.m2ts). Is there any plug-in or anything similar that will make my files loadable directly in After Effects?
Thanks in advance!
You need to convert AVCHD to a format AfterEffects can import.Originally Posted by SodRRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
All right, anyway I can do that without quality loss? I tried TMPGenc XPress but I get strange "lines" when the video "sweeps" horizontaly...Originally Posted by edDV
No, every decode and recode has quality loss.Originally Posted by SodR
As for lines, I'm fairly certain AfterEffects handles interlace. If you want progresive then you need to deinterlace causing more loss. If you want to use progressive AfterEffects, consider shooting progressive to start.
How many minutes are you putting through AfterEffects?
I'd use avisynth to decode and deinterlace to uncompressed progressive for short sequences.Recommends: Kiva.org - Loans that change lives.
I got my hands on AE CS4 which supports AVCHD so I guess I solved it that way. Thanks for the replys though
However when I'm rendering the video the video sometimes jumps back to a earlier frame and then back to the point "where it was" almost every second or two. The original video with a few effects applied on it plays fine in the build in AE "player" but in the jumping is visible in the preview of the video while rendering as well as in the final product. I have tried several different renedering settings (bitrate, format, fps etc) but it doesn't seem to help.
Any ideas? -
Since when does AE CS4 support AVCHD? Give me links. Last I looked it didn't even support SD MPeg2.Originally Posted by SodR
Also, is your computer still a Pentium 4 3.6?Recommends: Kiva.org - Loans that change lives.
Lol no, I got a Phenom 2 3.0Ghz quadcore.Originally Posted by edDV
Link: http://blogs.adobe.com/davtechtable/2008/09/intro_to_cs4_and_new_avchd_edi.html
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
What is the best special effects/visual effects software?
By dzsoul in forum EditingReplies: 37Last Post: 9th Aug 2010, 23:16 -
After Effects: copy effects to another composition?
By squadjot in forum EditingReplies: 2Last Post: 8th Dec 2009, 19:16 -
Do I need After Effects?
By hanexs in forum Newbie / General discussionsReplies: 13Last Post: 3rd Feb 2008, 22:06
