I am converting some episodes of tv 1:77 SAR divx files from an HD source(16x9). I am using TMPGENC AUTHORING WORKS 4 with the default settings. I want the dvd to play correctly on an hd tv or sd (4:3) If i choose 16:9 as aspect ratio they play fine on my hdtv but show a squished image on my regular tv. I have been searching for days online and have not found the solution to this. Do i need to convert them to 4:3 and reconvert them to 16:9 is there some option in Authoring works i am missing? Should i be converting the video to Letterbox first then making the dvd? HELP. I am aware of what the flags do in the ifo file but it still seems like i am missing a step here.
Thanks in advance
leave the DVD's as 16x9. All later DVD's are 16x9
Setup your dvd player to play the DVD letterboxed on your 4x3 TV, or pan and scan if you want to fill your 4x3 screen (but you won't see the sides of the picture)
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
How do I get 16:9 DVD video to play correctly on my 4:3 (regular) TV?
By chaacmool in forum Authoring (DVD)Replies: 1Last Post: 7th Oct 2009, 14:46 -
16x9 letterbox instead of 16x9 pan and scan
By CogoSWSDS in forum Authoring (DVD)Replies: 4Last Post: 30th Mar 2009, 05:08 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 02:26 -
Convert WXGA for 16x9 Projector
By Colmin in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 19:21
