writing from Germany, so please bear with me.....
I downloaded 83 Rapidshare files of the RnR Hall Of Fame 25th Anniversay concerts as MKV files (file name "The_25th.Anniversary_Rock_And_Roll_Hall_2009_x264 _HDTV_720p.mkv"......strangly enough they all run with a file ending 001-083 (Type). I tried to convert them with various programmes (ConvertX etc.) but none of these programms seem to recognize these kind of files.......not really sure what I'm doing wrong here.......any help/tips would be highly aprechiated.......thanks
thanks for your message.....I know.....there was a long gap, but I just did not need to use the forum......now with these new formats.....I'm just confused.......I already tried to Winrar them.......like opening the first file or all together......doesn't work.........also renaming them is not possible.......
I've actually seen longer gaps between posts, but do note that while you certainly don't have to post all the time here, posting 1 question and going away for 5+ years doesn't help you to LEARN anything. You can learn a lot just by reading the forums even if you never post.
Not enough info to help you. I'd need to see the complete name of some of the files, not this shorthand info you have given. Sounds like RAR files to me too, but do note that RAR files can easily be corrupted and P2P networks will just happily pass along the corrupted versions. This is why Usenet uses PAR recovery files with RAR. RAR is just too easy to corrupt. Also, it could be that the person who made it available did not know what they were doing. Or it was deliberately made bad and garbage was posted to waste your time. -
Highlight all files and right click "Open with" WinRAR.
If does not work , then try HJSplit (http://hjsplit.en.softonic.com/) -
I actually did read the forum quite a lot and learned over the years.......regarding this topic, I obviously checked if some simelar topic was talked about before I made my post........
to "ogk"
thanks a lot for your help......the use of HJSplit was the solution....the WinRar option I know and tried it before but without any luck
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 08:55 -
Dvd9 to mkv help
By HACKJACK in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2011, 01:23 -
10gb mkv to 2x dvd9?
By cv65user in forum Video ConversionReplies: 2Last Post: 3rd Dec 2010, 10:48 -
MKV to DVD9-DL (2) discs
By ranosb in forum Video ConversionReplies: 10Last Post: 5th May 2009, 02:56 -
Mkv to DVD9...Pls Help !
By john_triton in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2008, 07:57
