Results 1 to 15 of 15
  1. I downloaded an ISO file. I know you can burn with Nero Burning ROM to a DVD-R as a ISO file to play. Is there anyway to play directly off my computer? I tried to use Cyberlink Power DVD to play the ISO file, but doesnt seem like it works.
  2. Try VLC. Or use Daemon Tools to mount the ISO as a virtual DVD. Then use any DVD player, including the players mentioned above.
  3. Also, I am trying to move/copy this ISO file (about 4.5 GB size) from my computer to my external hard drive (which has 252 GB space left). It keeps telling me that "there is not enough free disk space" on my external hard drive. But I can move and copy other files of significant size, just not this particular ISO file.
    Why is that?
  4. IS your external drive FAT32 format? That has a 4 GB file size limit. You'll need to reformat NTFS.
    Nov 2009
    Do not use Daemon Tools as it now contains adware. Why not use this tool: http://wincdemu.sysprogs.org
    It is a very small program that works great and is open source.
  6. It is FAT32. If I reformate to NTFS, do I lose all 250 GB of data?
    Feb 2004
    Pleasant Hill, CA
    The conversion should not disturb the existing data, HOWEVER, as always, before doing anything of this nature - BACK UP first.
    Microsoft Technet has some info (and I'm sure you can Google for much more):
    http://technet.microsoft.com/en-us/library/bb456984.aspx
  8. Windows includes a FAT32 to NTFS converter. To be safe you should back up your data somewhere though.
    See the section entitled "Converting to NTFS Using Convert.exe":
  9. Banned
    Freedonia
    As the others have said, it will probably work OK. I work in IT for a living and the problem is that EVERYTHING Microsoft does is half-assed, so even though 99 other people may have done exactly what you did and had no problems, I can't totally rule out that some weird problem will happen for you and delete your data. The ONLY way you can be totally sure not to lose data is to back it up. Sorry. Years ago on my first XP box I did the conversion and lost nothing, but nobody can guarantee you that anything written by Microsoft will not have unintended consequences. Some of their tools work very well for the vast majority of users but a small minority will get completely hosed by them. There have been recommended patches that worked well for almost everyone but completely messed up a rather small number of PC users requiring a complete reinstallation.
  10. in layman's terms what is the difference between NTFS and FAT32?
  11. Anonymous
    Guest
    Removed.
    Jun 2004
    California,United States
    You could also just Shrink the file to 4gb or use Shrink and convert it to 2 smaller ISOs.
    Tony
  13. Member T-Fish's Avatar
    Apr 2009
    Switzerland
    or just unpack the iso as the vobs are only 1gb each.
    though i would advise converting the drive to NTFS anyway, unless you
    run win98 on it haha..
    Jun 2004
    Or want to plug it into a DVD player with a USB port. Almost all DVD players with USB ports only accept Fat 32. And though you may be able to convert from Fat to NTFS without losing data you will loose all data if you decide to go back to Fat32
    Tony
  15. My FreeAgent Theater can play ISO files directly on my TV.
