I'm wondering if anyone has an understanding of what Premiere/Matrox is doing with certain video I import. Here is the scenario. I import some none interlaced 320 x 240 video into the Matrox DV NTSC preset. Scale to frame size is selected so I have to render my timeline. I'm wondering if this video has now been changed to an interlaced format? Obviously it has been upscaled to fit the 720 x 480 dimension. When I export, would I then need to deinterlace even though my original footage was not interlaced?
Thanks.
Premiere is not changing your source files, but creating new preview files for the selected preset, using the Matrox DV codec. The Premiere/Matrox set-up should handle the interlacing, and if the final output looks okay, you shouldn't worry about it. I remember years ago having a Matrox RT-2500 with Premiere, and I could drop MPEG-1 files right in for output to DV without any alterations. Look for a folder on your video drive called Adobe Premiere Preview Files. That is where the convert DV avi files are stored. Look them over.
So when it is exporting is it accessing the preview file or the orginal source file?
How to Handle HD Video
By djtech2k7 in forum Newbie / General discussionsReplies: 5Last Post: 26th Mar 2012, 21:50 -
HELP!!! Can't handle home video..........
By George Bazeley in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2011, 11:23 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 11:06 -
Pbm of keeping presets when dropping a new video
By xaviermarichal in forum ffmpegX general discussionReplies: 0Last Post: 28th Jul 2007, 03:54 -
Is there a video card that can handle both: gaming & video editing?
By randyannie in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2007, 16:50
