hi...
I already have converted an mkv file to xvid (I needed to find a program that converted mkv to xvid or divx, but kept the high bitrate, resolution [hd], and 5.1 sound...and xvid4psp was the best one i found..if anyone found anything else, let me know)
anywho...i have "district 9"..and downloaded an srt file with subtitles just for the alien parts and i want to insert it in the avi file
the problem is that the virtualdub way that everyone suggests requires you to re-compress/convert it...I REALLY want to avoid this (since we can't use direct stream copy...)
is there any other way where you can just burn/insert the subtitles without reconverting the whole file?
any help is much appreciated =->
If you really need the subtitle burnt-in after recompression there is no other way.
On the other hand you can burn the subtitle in during your conversion
from MKV to XviD avi using Xvid4PSP.
The only quality loss you will get is the conversion MKV --> XviD avi.
Instructions to be found here: https://forum.videohelp.com/topic360276.html
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 16:18 -
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
ffmpegX - idx/sub subtitles lost in converting from avi to Xvid or DivX
By bonespur in forum MacReplies: 5Last Post: 4th Mar 2011, 03:25 -
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
Adding Subtitles to divx w/ a .sub file
By sean2a in forum SubtitleReplies: 5Last Post: 28th Sep 2008, 17:23
