I downloaded a bunch of HD video which is in mkv, im not really famillar with this container, and my dvd making program (ulead dvd movie factory) doesnt recognize it.
how can i convert it to another format without losing any quality?
is there a way to just turn it into Mp4 without re encoding, since that is the actual codec inside?
SUPER says that it is Format: MK , 3569 Kbps,
Video #0: codec: Mpeg-4 AVC
Audio#0: codec AC#
thanks for your help
You can try the payware ConvertXToDVD. It does a decent job of converting my MKVs to DVD format. There are some freeware converters in our 'Tools' section also you could try. https://www.videohelp.com/tools/sections/all-in-one-dvd-converters FAVC and DVDflick are popular freeware converters.
And you will likely lose some quality if you do any conversion. You may be able to extract the MPEG-4, but you would still have to convert it if you wanted to play it on most set top players.
And MediaInfo will give you a lot more information about the MKV files.
You can use tsmuxergui to change the mkv to .ts which ulead should recognize.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Mp4 inside Virtualdub (DirectShowSource is refusing)
By jairovital in forum EditingReplies: 21Last Post: 1st Feb 2012, 19:25 -
Please, advice batch converter what support .mkv with few subtitles inside.
By Nikolay_PI in forum Video ConversionReplies: 2Last Post: 24th Aug 2010, 12:56 -
Cutting/Stream-copying AVC1/AC3 inside MKV
By honeyko in forum EditingReplies: 0Last Post: 1st Nov 2007, 22:14
