All the episodes are in one big vob file and i need to convert them to a divx or xvid .avi files.I have tried HandBrake but it doesnt pick up any subtitles and their is still the problem of splitting it.![]()
It's not necessary (and as you're discovering, can be a pretty bad idea) to make one large VOB file. Just decrypt the episodes to the drive, each to its own folder.
Go back to the source DVD and start over by decrypting correctly this time. With an IFO, AutoGK can easily burn the subs into the AVI. -
I think the dvds I have might just be messed up I got em of ebay there are 2 0.99 gig files and a bunch of smaller files and IFOs
You're just describing a standard DVD, although if from E-Bay there's a good chance it's a bootleg and then anything can happen. Have you tried what I suggested?
Use DVD Decrypter set up for IFO Mode and not the default File Mode. Select each episode and decrypt each to its own folder. If all the episodes are in the same PGC/Title, then select the correct number of chapters that corresponds to an episode and decrypt. However, if they're all in the same PGC you'll have problems with the subs and your best bet is to encode them as a big movie and separate them yourself when all done. Separating AVIs is a simple matter.
Help Converting VOB File to MKV (including original AC3 and Subtitles)
By CCS4George in forum Video ConversionReplies: 1Last Post: 10th Sep 2010, 18:53 -
Converting .ogm to mpeg-4 with subtitles and multiple audio tracks
By Weasel3689 in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2009, 12:34 -
how can I rip my dvd tracks to individual .VOB file?
By dannieboiz in forum DVD RippingReplies: 6Last Post: 16th Jan 2008, 21:27 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
