Whenever I start my windows xp computer, it tries to load some weird file. Below is the error message.
Error loading C:\DOCU~1\ntload.dll
The specified module could not be found.
I cannot figure out where this is coming from or how to disable it from trying to load everytime I start my computer.
Results 1 to 30 of 41
Doesn't anyone Google anything anymore? Holy crap man.
http://www.threatexpert.com/files/ntload.dll.html -
hech54, thanks but I wasnt sure if that is a free tool?
I scanned with Malewarebytes Anti-Malware and SuperAnitspyware and couldnt remove this. -
did you look in msconfig/startup?
click start/run type in msconfig. click ok. click on the startup tab when the program pops up. scroll down the list and uncheck anything that tries to load that file.
it is not a program that pops up, just a error message with a red X (with message above)
Since you have SuperAntiSpyware....go to that program folder and open BootSafe.Originally Posted by jyeh74
Choose: Safe Mode - Minimal and allow the program to restart the computer.
THEN scan your computer with SuperAntiSpyware(and and other programs you may have).
**Don't forget to update all of the anti spyware software first** -
SuperAntiSpyware has all updates, let me rescan in Safe Mode and I will let you know what happens. I dont know what BootSafe is, but I'm assuming it scans in safe mode or something.
I will warn you that once a friend gave me a laptop and it had a dll on it that we could not remove, not even in safe mode. I don't remember the name of that dll file though. I tried everything to remove it, even booting Linux and using Linux tools to mount the disk drive and I still couldn't remove it.
Only the bad ones.Originally Posted by jyeh74
DLL's are Dynamic Link Libraries, part of many Windows programs.
http://en.wikipedia.org/wiki/Dynamic-link_library -
I think this Threat Analyser only scans certain documents/files. I cant scan my whole computer.Originally Posted by hech54
I basically turned it off using the msconfig, but not sure if that damages the computer. Would ideally like to remove it, but not sure what type of spyware/malware program to kill it with. Using Malwarebyets anti-malware, SUPERantispyware and Adaware which hasnt found anything. -
That is NOT what I recommended to do.
Bootsafe gets you to SAFE MODE.
You will now scan your computer WITH SUPERANTISPYWARE in SAFE MODE. -
What is safe mode?
Safe Mode has been a component of the Windows operating system since the days of Windows 95. The basic idea is to allow the user (or technical support worker) access to the windows interface without loading any unnecessary drivers or software. The thinking is that if device drivers or auto loading software (broswer hijackers for example) are causing problems with your Windows installation, the easiest way to fix things is to load a version of Windows that bypasses all but the most basic drivers and will not run any additional software. Windows XP safe mode provides you with a basic graphics driver (enough to display the user interface), access to your drives and windows configuration, and very little else.
http://www.pcstats.com/articleview.cfm?articleID=1643 -
thanks, let me try that. Is Bootsafe suppose to uncover spyware that normal mode may not reveal?
In a nutshell....yes. Spyware, trojans, etc etc etc are designed to hide....but they can only hide when they are running(in Windows). In Safe Mode....they are not allowed to run so antispyware stuff can catch them. You can get to Safe Mode without the program called BootSafe....but for a newbie or "rookie" to this sort of stuff...BootSafe is the best way to activate Windows' Safe Mode.Originally Posted by jyeh74
I always use BootSafe when I need to get to Safe Mode. -
There is a problem though. My computer does not restart. I do not know why as it has been a problem for quite some time now. When I try to restart, it will get hosed up and display a black screen, as if it cannot reboot. I typically just shut down, then turn back on, but this method (my only way) does not allow it to go into safe mode in BootSafe.
You think something is up with my hardware configuration? -
Time to go in the old fashioned way then:
http://www.computerhope.com/issues/chsafe.htmTo get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. -
if you download and burn to disc the dr web live cd, you can boot it and use the linux based a/v to scan your computer.
http://www.msk3.drweb.com/pub/drweb/livecd/--
looks like this virus, doesnt even allow me to get to links. i.e. if I google something, and try to lick on the links it returns, it RE-links me to weird pages.
hech54, so when I go into Safe Model (using the method you state above), do I just load BootSafe to scan? I thought BootSafe has to restart and go into safe mode itself, not manually as described above.Originally Posted by hech54
can you copy and paste or type in the url?
you really need to decontaminate that pc. malwarebytes and avast free editon are good. you should also run gmer to check for rootkits.
you may need to have a pro work on it, or consider re-formatting the hard drive and re-installing windows at this point.--
BootSafe isn't a scanner. I never said it was a scanner. BootSafe gets you to Windows Safe Mode.Originally Posted by jyeh74
Windows....in Safe Mode....is the BEST way to scan for hidden "nasties" on your computer. -
I wouldn't say that... at least, not after having seen rootkits that do their best to disable scanners and certain other processes from working, whitelisting themselves, disabling Safe Mode and System Restore...
Best would be not to boot into the infected system at all, so that the processes aren't running, and scan it from the outside. But finding a good scanner to do just that could be difficult.If cameras add ten pounds, why would people want to eat them? -
Not for a newbie or rookie who never even knew about Safe Mode until a few days ago.Originally Posted by Ai Haibara
hi hech54, my computer is F12 to choose start up mode. I try SAFE MODE and it will try to reboot my computer. I dont know what is wrong with my computer, but whenever it tries to restart, it just goes black and gets stuck. I even tried SAFE MODE WITH NETWORKING but doesnt work. I'm not sure what is wrong with my comptuer, but it cannot restart.Originally Posted by hech54
Ai Haibara, what do you recommend? I am running Malwarebytes' antimalware, SUPERantispyware and Adaware. Everytime I re-run the first two programs, it will find spyware (even though I just did a full computer scan the day before). These infections cause my computer to re-direct me to weird websites, not taking me to the links I want to go to. It constantly creates these pop-up sites from Google, to take surveys and make money, even though my security settings are set to MEDIUM and pop-up program is turned ON.Originally Posted by Ai Haibara
1090T Computer Won't Load DVD Players
By wulf109 in forum Software PlayingReplies: 7Last Post: 23rd Apr 2012, 14:25 -
Playing MKV with multiple audio tracks - does it load computer more?
By tufffta in forum Software PlayingReplies: 6Last Post: 4th Mar 2012, 18:44 -
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
My other computer runs o.k. after my browsers finally load...
By tcory in forum ComputerReplies: 3Last Post: 2nd Jan 2011, 22:28 -
AutoMKV problem, warpsharp.dll failed to load
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 09:32
