friends
i have sony XR500E camcorder, i have transfered the video in HD format to my pc and vegas shows me its 5.1 channel sound in it, but when i try to render the video in MPEG2 (DVD) format it shows me only stereo mode, and i want to render it in MPEG2 format with ac3 sound format so that i can hear 5.1 channel sound.
Please help me
Results 1 to 11 of 11
did you set your project file/properties/audio to 5.1?
you probably need to render them as separate streams. use render as dolby digital ac-3 pro type and the 5.1 for dvd template. and in your mainconcept mpeg-2 encode click custom and uncheck include audio in the audio tab.
friend the thing is i am having windows 7 64 bit, i have installed vegas pro 9 64bit and dvd architect 5 but whenever i try to render it as ac3 it says "The AC-3 plug-in is currently unavailable. You can unlock this plug-in by installing and registering DVD Architect Pro" i have tried uninstalling and installed again but still not available, i think its because of 64 bit operating system. please do something else for me
try sony support. it works fine in the 32 bit version of win7.
can you please guide me any other software name by which i can render my HD quality video to DVD quality in ac3 format?
adobe premiere pro cs4 or maybe surcode soft encode if you need a 5.1 ac-3 encoder. don't know if that last one works in win7 64bit.
yes TARRICKB i have tried both but both gives the same error.
Thanks AEDIPUSS i will get adobe premiere pro cs4 today only. -
sorry i forgot why i had surcode. it is the required plug-in for pp cs4 to get ac3 5.1 output. you need to buy it separately.
http://www.minnetonkaaudio.com/products/surcode07.html--
AVCHD 24 Mbps and Vegas Pro 9, 10
By shaema in forum EditingReplies: 5Last Post: 27th Jul 2011, 09:11 -
Convert HD MKV or AVCHD to HD MPEG2/AC3, with subtitle support?
By elsinga in forum Video ConversionReplies: 14Last Post: 25th Dec 2010, 13:56 -
Vegas Pro 9 get timecode from AVCHD
By flamadiddle in forum EditingReplies: 12Last Post: 6th Jan 2010, 15:40 -
Rendering AVCHD In Vegas Pro 8
By luisgmarine in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 00:03 -
DVD output from AVCHD and Vegas Pro?
By theaterguy in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2008, 02:56
