    Feb 2008
    Trying to rip a DVD with AutoGK, copied DVD files to HDD with CloneDVD (and tried DVDShrink).. VOBs play perfectly in VLC player but when I use AutoGK the audio is out of sync (same amount all thru I think).
    Also tried AVS video converter - same problem.
    If I use ConvertXtoDVD to reconstruct the Video files , that also works fine without showing any sync adjustments.
    I ran FixVTS on the VOBs but that didn't solve the problem either.
    Any ideas please?
    Feb 2008
    Thanks, strangely though, Mediacoder does the job properly so it is an AutoGK problem.. the VOBs are fine.
