  1. HI,
    OK here's the thing : I'm tryin'to convert with cce 2.5 ( captured dv avi's )
    I let it frameserve with virtual dub ( first I resize to 480 to 480, also I export the wav to later convert it to .mp2 file with tmpg)
    In cce I tried several options ...did the cbr on several bit rates from 6000 to 2400. did one pass .... but after I multiplexed them in BBmpeg..the result is still bad ( video and audio are not synch!)
    Can someone please help me with perhaps the best bitrates, BBmpeg settings???? I hope so ... I know it can work and CCE can create very good SVCD'S
    Marhart
  2. Hi ,
    forgot to mention that I also did Pulldown on the .mpv file after CCE encoded!..sorry
  3. Is the Audio out of Sync when playing the movie at regular speed from the start or does it get out of sync when moving the slider of the player to a later scene ?
  4. I had a similar problem and I read on a FAQ somewhere that PC playback may be screwed up but the SVCD burn will play perfect on standalone. I tried it with “The Cell” and it worked. On my PC the video was jerky and the audio was out of sync. First, I cut a small piece of the mpeg and burned to a re-writable and tested. Plays perfect on my JVC.
