I have doubts about how Ripbot264 works :
If you try to do more encodings , one after another, ie consecutives , ripbot gives error in the sense that all files made encoded, no matter what name they have or what size , it selects its first encoder always ...
( For instance , If I try to encode a serial movie , having 5 episodes , after Ripbot finishes the first episode , if I select the second episode to be encoded , the soft " takes " the same first episode end encodes it.)
I wonder what should I do for that Ripbot264 to "forget" the first encoded file and start to encode the next ones.
I've removed all the softs that was encoded first time , I've deleted all from the memory ,I've closed the soft and started again , but for nothing( It remember the first episode and encodes only this one...It cannot jump to the second , third , aso...)
I prefer to answer me one of owners of this soft or a specialist in Ripbot.
Thanks !!
@hech54
What do you mean ??? Pls , do not be so short of expression...
The sentence above is a...question or an a statement ????
demux errors with ripbot ...
By zero7404 in forum Blu-ray RippingReplies: 7Last Post: 13th Sep 2012, 21:13 -
ripbot 1.17
By zero7404 in forum Blu-ray RippingReplies: 17Last Post: 27th Apr 2012, 11:25 -
Ripbot 1.14.6 is generating errors when loading a m2ts file
By playitagain_sam in forum Blu-ray RippingReplies: 0Last Post: 29th Dec 2009, 09:59 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
