Yeah, my tablet worked right away (essentiallyOriginally Posted by DarrellS) when plugging it into an XP or Vista32 system. I just wasn't sure how easy it'd be with a 64-bit system.
Are you sure Adobe doesn't have any fixes to get the pre-CS versions of Photoshop to run on a 64-bit OS? (Long shot, perhaps.) I wonder how well it might run under a virtualized 32-bit XP.He has Photoshop 5.5 and it will not install on the XP 64 bit machine. Says the OS is not supported. I don't think he would pay $1000 for a newer version even if he wasn't unemployed right now. He'll just have to use it on the computer with XP 32 bit. Photoshop 7 is a CS version right? I believe they will all install on a 64 bit machine but I'm not sure if they will run in 64bit mode or just 32bit.
Results 31 to 32 of 32
I would only suggest ImageReady.
Video to .gif converters? (animated gifs)
By Hank Kinsley in forum EditingReplies: 1Last Post: 31st Aug 2010, 00:13 -
Can I easy resize from very fine 4:3 to very good quality widescreen??
By vantechmag in forum EditingReplies: 9Last Post: 15th Nov 2009, 10:10 -
Animated QT file
By tb582 in forum Video ConversionReplies: 4Last Post: 8th Apr 2009, 22:30 -
HD Animated Backgrounds etc
By jamesbustar in forum EditingReplies: 1Last Post: 7th Apr 2009, 09:31 -
animated gif
By snafubaby in forum Newbie / General discussionsReplies: 14Last Post: 27th Jan 2008, 14:41
