Hello,
I am trying to edit some home movies I have on DVD, well not edit..basically I want to remove all the audio and replace it with another audio file of the same length.
Here is the problem...when importing the DVD in TDA the video shows and plays as a black screen...I can hear the source audio but the video only shows black. Is there a codec I need to install for TDA to play the video preview and burn the new movie?
I dont want to spend the time burning the movie to have it play a black screen in my DVD player. Has anyone had this problem before with TDA?
thanks
Can you watch your dvd on your computer with powerdvd or windvd or another software dvd player?If not then you need to install one of them to see if the dvd plays ok.Also you can try media player classic home cinema.
If you are talking about the edit screen (where you set chapter marks, etc.), right click on the monitor and uncheck USE HIGH SPEED DISPLAY MODE.
Hope this helps.
Brainiac -
I right clicked but dont have an option for USE HIGH SPEED DISPLAY MODE
TMPGEnc Authoring Works 4.0.12.42
I was having the SAME problem with the "Black Screen", this is how I solved it:
First, I installed "FFDSHOW 1.3.4504 [2013-03-12]" for "ALL" your CODEC!!
You can access the cut-edit stage by clicking on the "Cut-edit" button located on the top part of the Clip editor window, Right click on the "Black Screen" and Uncheck--->Display in a video overlay. If you did it correctly, you should be able to "Watch" your Clip/ Movie.
This is the DEFAULT setup:
1. Display at source size [ Unchecked ]
2. Display at window size [ checked ]
3. Display at original aspect ratio [ Unchecked ]
4. Display at corrected aspect ratio [ checked ]
5. Display in a video overlay [ checked ] CHANGE to [ Unchecked ]
6. Display on progressive mode [ checked ]
7. Display on low quality mode [ checked ] CHANGE to [ Unchecked ] for ("High Quality")
8. Display settings
9. Save current frame in picture file
10. Copy current frame to a clipboard
Finally, Your screen should be working correctly, DONE!!
HuGo BoSs [04.03.2013]
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 02:25 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
By mobie29 in forum Authoring (DVD)Replies: 4Last Post: 7th Apr 2010, 20:30 -
Tmpgenc authoring works
By hamilton accie in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 08:32 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15
