Hello
I've got a friend that is trying to convert his HD mov videos so he can edit them in vegas. What software would you recommend to use that would convert the mov file so its editable in vegas, and achieving the best possible quality.
THank you![]()
I get 720/60p H.264 files from my Canon 7D and use MPEG Streamclip with the Avid DNXHD codec to convert the files prior to editing in Sony Vegas Pro 9. MPEG Streamclip and the Avid DNXHD codec are free, but be prepared as the converted files are about 1GB/min of video!
Also, Vegas Pro 8/9 supports these files with Quicktime installed, but it is MUCH easier to work with them (within Vegas) after converting to the DNXHD codec.
Here is a great tutorial I found online:
http://eugenia.gnomefiles.org/2009/11/20/loading-canon-digicamdslr-footage-on-avid-mc4/
Does Sony Vegas Movie Studio HD Platinum 10 do 60fps?
By vid83 in forum EditingReplies: 13Last Post: 7th Feb 2011, 19:33 -
Editing AVCHD .mov files straight up in Vegas
By TigerSoul in forum EditingReplies: 11Last Post: 11th Mar 2010, 12:51 -
Can I edit HD MOV files with the newest Adobe Premiere or Sony Vegas?
By vatkat234 in forum EditingReplies: 3Last Post: 16th Nov 2009, 18:47 -
Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..
By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 16:04 -
Converting a mov format to avi in Vegas 6.0
By solarblast in forum Newbie / General discussionsReplies: 10Last Post: 25th Sep 2007, 11:29
