Hey, I've always used MPCHC + Haali Renderer to view my videos but I just noticed switching from Overlay Mixer and Haali's I get a boost in saturation or such from haali's. Also I just found out haali does auto deinterlacing on interlaced footage, Overlay doesn't.
I just also compared the pictures in Sony Vegas and MPCHC + Overlay Mixer and it looks pretty much the same.
Should I just use overlay mixer to view my videos for color correcting to web then, since it matches the video in my editing program it should be accurate right?
I realize many people view videos differently, but I'm trying to find the way most people play them and I'm guessing Windows Media Player and Quicktime, I probably should just see if those match the video in my editor as well.
Anyway, I always thought Haali Renderer was the best to use and was told that, so I'm kind of confused.
I would search and read http://forum.doom9.org/showthread.php?t=123537 and http://forum.doom9.org/forumdisplay.php?f=15 if you use MPCHC. But it's usually up to you what looks best.
This doesn't ensure anything. If you are color correcting for web, you should test using the same flash player and front end that website is using. e.g. use an offline local webpage on your computer to play your videos, but test the entire process from start to end, even uploading to the website. Adobe Flash doesn't use the same renderer as your media player uses, and it uses it's own software to do YUV=>RGB conversion (one of the reasons why it's so slow)Should I just use overlay mixer to view my videos for color correcting to web then, since it matches the video in my editing program it should be accurate right?
You could render some test chart videos, and color bars with grey scale and levels, and note the differences as viewed in vegas or whatever your editing program is , as opposed to the final product as viewed in the flash player. The project settings you use in vegas make a difference (e.g. linear gamma vs. 2.222 in 8bit vs. 32bit projects) , as do your settings you set your scopes calibrated to
How can I ACCURATELY split/cut a video file?
By KushSmoka420 in forum EditingReplies: 5Last Post: 2nd Mar 2012, 14:16 -
Need a multi view video player- ADVICE PLEASE
By rosewarburton in forum Newbie / General discussionsReplies: 0Last Post: 27th May 2010, 08:49 -
How to view .mpg video and subtitles in QT Player?
By davecc in forum MacReplies: 6Last Post: 26th Jun 2009, 08:22 -
DVD RIPPING....Problem syncronizing video with audio accurately.......
By R.STEED in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2009, 20:14 -
best app for burn a video clip to view on a DVD player?
By yolao in forum VCDEasy GeneralReplies: 0Last Post: 8th Jul 2007, 13:34
