I have just burned a VCD and played it on my DVD-player,
this is the first time I have done a VCD. Normally I convert to SVCD.
But VCD looks great!!
Is there any reason to covert to SVCD instead of VCD, it wpuld save some discīs.
VCD works in alot more players than SVCD and uses less space. But VCD gets really good, if your player will read non-standard VCD's like my Sony 325. Instead of 352x288 I use 720xHHH (HHH being the height of the clipped movie, usually between 320 and 420). In other words I use DVD resolution and my Sony plays it !!! Also I use different bitrates all the way up to 3000 instead of the 1150 standard. Together I get results from my VCD's that are nearly DVD-Quality, fitting any normal movie on 2 CD's. Experiment with your player, try the high resolution and different bitrates and if it works, just forget about SVCD !!
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
VCD o SVCD with extra data (installers)
By pmaril in forum Authoring (VCD/SVCD)Replies: 12Last Post: 17th May 2008, 18:17 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 11:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 11:27
