Hi,
I am relatively new to burning movies onto DVD. So far, my friend used to do it for me, so I was set. But now I since I moved to a different place I need to learn.
I need a freeware to burn movies I have downloaded onto +DVD.
I have bluray to dvd rips of abt 4.2 GB as well as 7.8 Gb movies. Will this content remain the same in quality when I burn them onto a DVD ?
Any help will be appreciated.
Also I have some .ICO images of PS2 games that I need to be able to play on my modified PS2.
CSUGAL999
	Assuming the Bluray rips to be MKV format H264/DTS/AC3 files (use mediainfo to confirm this) the files will have to be converted to DVD spec format, and you will see a large reduction in quality.
 If you have a bluray player or PS3, use Multi-AVCHD to create an AVCHD format structure, burn to a blank DVD with imgburn, and you will lose very little quality.
 If you only have a stndard DVD player then use AVStoDVD to create a DVD structure, burn to a blank with Imgburn, and play on any dvd player.
 Imgburn does not appear to support the ICO format - are you sure you don't mean ISO ? If so, burn with Imgburn and playRead my blog here.
  best software to burn avi videos to DVDBy jomuir in forum Authoring (DVD)Replies: 16Last Post: 14th Feb 2012, 11:23
  Burn an AVI file on a DVD - Best software to do thisBy tim_ver in forum Newbie / General discussionsReplies: 11Last Post: 26th Sep 2008, 14:51
  Need freeware software to rotate avi file.By Confused Chimp in forum EditingReplies: 5Last Post: 9th Jan 2008, 13:47
  Any freeware or open source DVD menu software can do this?By csh in forum Authoring (DVD)Replies: 1Last Post: 29th Nov 2007, 06:48
  Burn Software with Menu & burn xvid aviBy CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
