Not sure if this is the correct forum but all I'm trying to accomplish is transferring video files from one PC to another using an ieee (1394a) connection. What do I need to do other than connect a cable between the two? Thanks in advance!!
Results 1 to 23 of 23
dbanimal
Computer section is better. Moving you.
Or do you mean that you want to CAPTURE the video from the other pcs video output? Not just move data video files. -
you most likely need shared folders on both computers.
Nope, just move video files from one PC to another using firewire.Originally Posted by Baldrickdbanimal
This is true if I were to use ethernet to transfer, which I have been but takes forever. The thing is, I need both PC's to see eachother's firewire connections, I'm not sure how to do that.Originally Posted by aedipussdbanimal
http://www.kiva.org/about -
A Gigabit switch is good for 40-50Mb/s sustained real world, I just bought 2 D-LinksOriginally Posted by dbanimal
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127083
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
firewire uses tcp/ip just like ethernet. same sharing applies, but it can approach 400mbits/s. all that's needed is plugging in a firewire cable connecting each computer. personally i'd use 4 pin->4pin and not any 6 pin wiring. the 6 pin wires have live voltage and may fry a bad connection.
gigabit switches/routers are capable of 125mbytes/sec or 1000mbits/sec.
windows home networking blows and you may see much lower speeds than max in each type of network.--
You do that by enabling file sharing over the firewire port. Windows 7 has removed this capability.Originally Posted by dbanimal
That is the gigabit "theoretical" max speed, but in the real world you get about half that, just like usb only gets about half its theoretical max speed in the real worldOriginally Posted by aedipuss
Why does Windows Home Networking "blow" my friend? lol Your network is only as fast as your hardware, and short runs make for higher speeds
All my PC's have gigabit ethernet which is pretty much useless for ultra high speed tranfers from the web, but fantastic for shuttling uncompressed blu rays between PC's
My transfers on my own Windows 7 Gigabit Home Network start out @ 90mb/s and wind down slowly to about 46-47Mb/s, 4x faster than I can transfer @ work w/ a 10/100 connection (General Motors Engineering World Head Quarters-Warren, Michigan)
Where the connection wins @ work is I get the full 11Mb/s downloads (10/100) from the web where as my 16mb comcast connection won't get more than 3Mb/s downloads (24mb)
ocgw
Linux on the same hardware has greater real world throughput.Originally Posted by ocgw
Really?Originally Posted by jagabo
How much and how come?
Can you run a Windows 7 or XP virtual PC in Linux?
I just downloaded Ubuntu, gonna' try it out on some older gear I have
ocgw
Thanks for the responses guys and Merry Christmas!! I will give some of this a try!!
One other thing to mention, the one PC is running Vista Home Premium and the other is running XP Pro. Will this cause conflicts by chance??dbanimal -
Only XP supports networking via FireWire. MS removed it from Vista and isn't part of Win 7 either. At the time, integrated FireWire was not common and MS could not justified ongoing support for a feature they saw as of little value.Originally Posted by dbanimalJohn Miller
If I may reiterate, "Gigabit Windows Home Network", not hard to setup, gear not expensive, faster than firewire
fast ethernet (10/100) < Firewire 400 < usb2.0 (480mb/s) < Firewire 800 < gigabit ethernet (10/100/1000)
http://www.lyberty.com/tech/terms/usb.html
According to Tom's hardware gigabit ethernet is even faster in the real world than Firewire 800 (iEEE 1394b)
http://www.tomshardware.com/reviews/drivers-improve-windowsxp-service-pack-2-firewire,867-7.html
Rosewill 10/100/1000 5-port switch (5-eggs) $25USD
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166036
D-Link 10/100/1000 5-port switch (5-eggs) $30USD
True plug and play setup on the D-link by personal experience
Don't make it any harder than it has to be if you don't need to
ocgw
Ah, I see. So I'm wasting my time trying to get this to work then I take it?!?!Originally Posted by JohnnyMalariadbanimal
Be much easier to use a 8gb flash drive and copy files that way from one computer to the other.
If you already have ethernet ports on both computers all you need is a crossover cable.
http://www.amazon.com/Belkin-A3X126-03-YLW-M-3-Foot-Crossover-Yellow/dp/B00004Z591/ -
Detailed info
http://lifehacker.com/173973/geek-to-live--fast-one-wire-network-ip-over-firewire
On December 4, 2004, Microsoft announced that it would discontinue support for IP networking over the FireWire interface in all future versions of Microsoft Windows. Consequently, support for this feature is absent from Windows Vista and later Windows releases. -
I believe MS never wanted to support firewire because it was a Mac invention, didn't firewire arrive before usb2.0?Originally Posted by JohnnyMalaria
firewire (2003)
http://en.wikipedia.org/wiki/IEEE_1394_interface
usb2.0 (2001)?
http://en.wikipedia.org/wiki/Universal_Serial_Bus#History
Wiki says usb2.0 was first, but I think that was just on paper, I am sure I had my Sony DV firewire camcorder before usb 2.0
ocgw
Point to point IEEE-1394 (Firewire 400) serial communication has been supported by Apple OS since 1995 and natively by Win98SE since 1999. Third party apps offered IEEE-1394 for Windows back to Windows 95.
Windows IP networking over IEEE-1394 is a separate XP (2001) application. Similar functionality was available from by third parties back to Windows 98/2000. This feature was dropped in Vista/Win7 but standard IEEE-1394 communication is supported.
http://www.homenethelp.com/network/firewire.asp
In 2001, Apple OS introduced a feature called Target Disk Mode (TDM) over Firewire that accessed remote disk transfers but never supported Firewire networking with either UNIX or Windows networks.
http://en.wikipedia.org/wiki/Target_Disk_Mode
Apple added support for limited IP networking over IEEE-1394 in OSX 10.3 (Panther 2003).
IEEE-1394 over Cat5 Ethernet cable will be possible with the future IEEE-1394C standard.
http://blogs.zdnet.com/Apple/?p=2414Recommends: Kiva.org - Loans that change lives.
Transferring DVR files to laptop
By billiejean in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2009, 13:17 -
transferring files from the PC to mobile phone
By sumeshkri in forum AudioReplies: 3Last Post: 19th Sep 2008, 07:26 -
Transferring Music Files
By mccoady in forum ComputerReplies: 5Last Post: 14th May 2008, 11:41 -
Transferring files to ffmpegX
By Bigdaddy04 in forum ffmpegX general discussionReplies: 2Last Post: 7th Mar 2008, 13:42 -
transferring DV to AVI files but can't get the datestamp
By orduser in forum Newbie / General discussionsReplies: 14Last Post: 14th Dec 2007, 17:00
