I'm loading Windows7 on my new computer. It's got an i7-860 2.8G Quad. Is doing a "burn-in" for the CPU still part of the deal?
Depends on the heat sink compound used. Most newer ones don't need much if any break in. And unless you overclock, not much point. I would check the CPU temps with something like HW Monitor: http://www.cpuid.com/hwmonitor.php
Or you can run something like Prime95 if you really want to stress it: http://files.extremeoverclocking.com/file.php?f=103 -
I never did "burn in" ever.
It is not necessary ... but more useful as a method of stressing the components / system for stability purposes
I only do this with problematic systems via the ultimate boot cd utilities
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
