I'm using Nero Vision to capture video from a miniDV camcorder, then hopefully split the captured video into multiple files and then burn them onto a DVD.
First question is file format when capturing. The default format is DV and the video worked fine but the audio was a disaster. DVD format gave me an error about analyzing the file. So I went to AVI. Now the problem is that a 40 minute long video takes up 45GB. I'm new to video editing....is that normal?
I went along with it anyway and started to cut the video, but before I go any further I wanted some experienced opinions. Is AVI the best way to go? I suppose I could use autoGK to reduce the file size, but I dont want to lose any quality from the original.
Any help would be appreciated!
An uncompressed AVI takes up lots of space that's why compressions such as divx & xvid are popular. Anytime you compress a video you will loose some quality. How are you transfering the video to your PC? USB or Firewire?
Compression is not always noticable. When I have captured from my Camera to my laptop (vista) by firewire simply the act of turning on my video camera activates a program "media import wizard" and it does a good Job, Nero is a good program that sometimes has a mind of it's own.
If you are just cutting you can use Windows Movie Maker. It won't recompress the unaffected parts of the file. Of course it will take the time needed to copy the frames from one file to another. If you go this route then make sure WMM is set to output to DV AVI.
But - as stated above - it doesn't seem your files are necessarily in DV format (40 min of DV should be approx 8GB).John Miller
complete camcorder virgin looking for a (up to)$850 camcorder
By rocketman122 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Aug 2010, 11:34 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 04:09 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 13:47 -
Camcorder to DVD Problem using NERO
By rhodellf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 3rd Oct 2007, 19:51 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
