I have a dvd with vob files that I need to merge into one file before after or during a conversion to mpeg.
Any suggestions how I can do that?
I've found converters, but I'm not finding something that will merge.
For instance - just to be clear - I have a dvd with 30 mins of record time, then a break, then an hour of record time, then a break, then 45 minutes of record time - I think my math is off there (no more then 2 hours on one dvd). Anyway I"m sure you get the picture. I need all those pieces "pieced together/merged" so they created one mpg file.
In advance, thank you
You don't need to convert to mpeg. The native mpeg video is already inside the VOB container.
VobMerge has a little quirk in that it works best when you send the output file to the same folder as the source VOB files.
You can extract the mpeg stream from the vob with vob2mpg, or you can change the .vob extension to .mpg. -
Well thank you very kindly.
What are the quality issues changing the extension?
It's possible a .bat for avi that convert at 25fps and merge with mp3 ?
By Robertus in forum ProgrammingReplies: 10Last Post: 14th Aug 2010, 12:36 -
ffmpeg merge + convert
By tl29steeler in forum Video ConversionReplies: 3Last Post: 16th Nov 2009, 08:24 -
Merge multiple VOB then convert to DivX
By submanic in forum DVD RippingReplies: 24Last Post: 19th Sep 2008, 14:39 -
Video Convert/Split/Merge Studio
By jos789 in forum Video ConversionReplies: 3Last Post: 5th Nov 2007, 10:32 -
Merge two avis into one then convert to dvd
By pseudoman in forum EditingReplies: 1Last Post: 24th Oct 2007, 23:49
