Hello,
I have an avi of a video (which was dubbed in russian, with the original english stream present in it as well)
I was able to use VirtualDubMOD and get the English stream seperately.
I then combined them together. However, when I watched it, the audio hardly fitted in with the video. I noticed that the video length was much less than the audio was.
Is there any way I can synth the audio and video together? Thanks very much
				Results 1 to 12 of 12
	The video length is 1 hour 34 minutes and 28 seconds, while the audio length is 1 hour 45 minutes
 I ripped the audio again for a second time. This time, it came up to 1 hour 34 minutes and 28 seconds (same length as audio) but I noticed that a bit from the end is missing.
 thanks
 is there a tutorial or something I can read about stretching the audio as you mentioned? thanks again
	What format is the audio stream? Mp3? Ac3? Something else? See if the audio stream is VBR (variable bitrate), which can be misread by some players. If so, I suggest you encode at CBR (constant bitrate).
	Thanks everyone! I will try those other programs and post back here with the results
	Hi
 I seperated the audio stream and the video using Avidemux and got two files.
 The length of the audio file is now 1 hour 33 minutes and 9 seconds, and the length of the video file is 1 hour 34 minutes and 28 seconds.
 I combined the two together using Avidemux and the file I got was well in synth and worked perfectly until about 4 minutes in. After that, the audio seemed to move a bit fast for a second or two, and from that the audio and video seemed to get more and more apart.
 And filmboss80, could you tell me how to encode the audio the CBR if possible? thanks
 I also downloaded audacity, and tried to load the file into it, but it started by saying it will take a few seconds to extract the mp3, and then the time started stretching into hours until it came to 10 hours, and still was increasing. Does that mean there is something wrong with the audio?
	Oh, and something else I noticed is that, on the merged video, at around 5 minutes into the movie, the audio and video are separated by about 2 seconds, with the video coming first, and then the corresponding audio coming next.
 At about 40 minutes into the movie they are seperated by about 10 seconds, with the video coming first, and then the audio coming (ten seconds) after
	For changing VBR to CBR, I would go back to what you first did in VirtualDub (of course, make sure you have the Lame mp3 encoder installed), with just this change: Under Audio, make sure you're in Full Processing Mode. I suggest you also go under Audio > Conversion and tick 48000Hz, 16-bit, Stereo. Thereafter, go to Audio > Compression, and make sure you have Lame MP3 selected. There should be a box to the right hand with a list to select from (if not, tick "Show all formats"), and you should select 48000 Hz, 128 kbps CBR, Stereo. (You can go higher than 128 kbps, but this is a good and generally safe bitrate for divx and xvid avi movies. Above all else, make sure you don't have ABR selected.)
 On the video part, select "Direct stream copy" so that the video stream of the AVI is not reencoded. Then go with File>Save as AVI.
 Give that a try. If only the audio stream is being changed, the process should not take very long.
 See if it works.
	I tried it with VirtualDub ... unfortunately it didn't work. I'll just do the same thing with Avidemux and see how it goes
  HD TV to Laptop Problem (connecting audio and video simultaneously)By hamid22689 in forum DVB / IPTVReplies: 7Last Post: 14th Mar 2012, 11:35
  Video + mono -> Video + Left & Right audio dubbingBy mmafan in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 18:35
  Removing audio and adding it to new video...helpBy dandad1 in forum AudioReplies: 1Last Post: 2nd Dec 2008, 02:34
  removing audio from video fileBy kpeecee in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 11:36
  Removing and Adding New Audio to Mpeg Video for DVDStyler MenuBy dennis albright in forum EditingReplies: 0Last Post: 25th May 2007, 08:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
