Hi,
I would like to know how can I with open source tools, or delphi application can create a mpg file that contains an audio track and four video frames one in the beginning to in the middle and one at the end of the file.
* I have bought the wrapper of the ffmpeg to delphi objects, and according to their support they do not know exactly how to make such a file using their tool.
* Currently I used an open source tools which were ported from linux and that create a multiplexed (combined) mpg file that contains one frame in the beggining and an audio track. The tool is called mplex.exe -- apparently I do not know whether that tool can create what I need as described above.
If you got any lead or proper explanation please reply.
Originally Posted by nighthawk2018
With Windows freeware: Could do it with Avisynth (to make the images into video), HCEnc to convert to MPEG, an audio encoder or editor (Audacity can do both), and a multiplexer to combine the video and audio (eg, mplex, or easier, ImagoMPEG-Muxer).
See http://avisynth.org/mediawiki/ImageSource for examples of Avisynth scripts to make sequences of images into video. -
Hi Again,.
I have downloaded the AviSynth and it seems to have many features, It will take me some time until I find a way to use the embedded .dll in my delphi application. Do you know where can I find a sample of a .avs file that use the minimal resources in order to produce a mpg file? I would like to produce a small sized mpg file, and it seems that the DVD Slide Show GUI can make some samples but it result with a big mpg file. Whereas I would like to make it smaller file so I could fit many on one media.
Thanks in advance,.
Creating flash/mpg/etc slideshow with text from file
By RandallM in forum Newbie / General discussionsReplies: 0Last Post: 12th Nov 2010, 12:50 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 17:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 08:47
