I capture TV Shows with my TV Tuner card (youtube - happydog500). Sometimes edit and burn them on DVD. Right now I use my internal IDE HD. I want to get an external HD. It's a USB.
IDE is faster then USB.
When my card is capturing (recording), will the slower USB, be two slow?
When I edit, then render, will the slower USB HD add a significant total time?
If I capture on my current HD, then cut and paste to the bigger USB HD, will copying the file make it worse looking?
Anything else you can add to any of these questions?
Thank you,
Chris.
Is the ComPro Gold a hardware encoding card? If so data rate will be small. If you are capturing uncompressed you will have problems with USB. Get eSATA instead.
http://www.kiva.org/about -
Man, it was really tough to find information that tells, but the company website does say that the card does hardware encoding. You really have to dig to find it. That's if this card is the TV Gold Plus card. I couldn't find anything on just a TV Gold card. I looked it up because I had the feeling that the original poster might not know (I apologize if he did know).Originally Posted by edDV
I looked too and couldn't find specs.Originally Posted by jman98Recommends: Kiva.org - Loans that change lives.
Simple answer, Yes, most of the time, IMO. Depends on what you are doing. USB is fine for small files, but may have problems with very large files. The main problem with USB is the OS likes to mess with the USB interface, so it can be very slow if you have a lot of USB peripherals and the OS is checking them all the time. I would also recommend eSATA if you want to use external drives and access/throughput speed is a concern. eSATA runs the drives the same speed as the internal drives.
PotPlayer: no audio switching, no subtitle switching
By Anonymous9843 in forum Software PlayingReplies: 1Last Post: 6th Oct 2012, 22:44 -
Incomplete installation of a usb Rocktefish ide hd enclosure
By yoda313 in forum ComputerReplies: 6Last Post: 5th Jul 2009, 20:30 -
About IDE to USB adapter cable
By AusTaylor in forum ComputerReplies: 7Last Post: 4th Feb 2008, 01:18 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 19:23 -
Dreamhost incredibly slow.. thinking of switching to a new host - which one
By Garibaldi in forum ComputerReplies: 0Last Post: 17th May 2007, 16:59
