Hi,
I need some help with the editing of a 8 mm film. We shot the whole film with 8 mm camera's and digitalized the footage.
Now it's a bmp sequence, but i don't really now the best way to approach it in Final Cut Pro.
Someone tolled me you should edit with a converted smaller sized copy and once finished apply your project on the real master footage.
Does anyone have experience with this?
18 or 24 fps? What frame resolution?
Premiere would be better for this project. For Final Cut, you need to externally convert your BMP's to a FCP supported format.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Super 8mm film to video
By Mike99 in forum Capturing and VCRReplies: 3Last Post: 26th Feb 2012, 01:53 -
BMP to AVI sequence
By max_e_mum in forum EditingReplies: 6Last Post: 17th Aug 2009, 06:57 -
8mm super film workflow questions
By Smile_M in forum RestorationReplies: 1Last Post: 7th Aug 2009, 16:21 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 22:28
