I have a movie file in mkv format (x264-AAC), which I want to convert into a format playable on my standalone dvd player (supports xvid, divx-ultra, svcd, dvd etc). Also I only have a CD-RW burner, so the output file should preferably be able to fit on 2 CDs (700MB-80Min). Since I don't have much experience in encoding, can anybody suggest how I could go about doing this with minimum loss in quality from the original video. Re-encoding does seems necessary in this case.
Original video MediaInfo stats:
http://i91.photobucket.com/albums/k292/abs724/Screencaps/MWSnap00a.jpg
http://i91.photobucket.com/albums/k292/abs724/Screencaps/MWSnap00b.jpg
http://i91.photobucket.com/albums/k292/abs724/Screencaps/MWSnap00c.jpg
to convert mkv to avi : https://forum.videohelp.com/topic241422.html
then search for "avi splitter" to split the avi -
The tutorial says direct stream for the video part. Does x264 AVC video play in most average DVD players !
Nope. So you need to convert. I would probably use a simple all-in-one converter like xmedia recode, format factory or xvid4psp.
No. Most of them are limited to DivX/Xvid, and might also let you play MPEGs from the file menu. But that's usually about it.
My 5990 also allows WMV, to an extent, but that's rare.If cameras add ten pounds, why would people want to eat them? -
Note that if your source MKV uses a resolution greater than 720x576 that your DVD player may refuse to play it. If the source file resolution is larger than that, I would suggest that as part of your conversion process that you drop the resolution to get it below 720x576.
high quality mpeg-2 encoding
By deadrats in forum Video ConversionReplies: 202Last Post: 19th Jun 2012, 17:58 -
subs loses quality after encoding
By evile1690 in forum SubtitleReplies: 11Last Post: 2nd Sep 2008, 08:17 -
Best quality settings for Xvid Encoding
By Shibblet in forum Video ConversionReplies: 1Last Post: 1st Sep 2008, 20:50 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 10:55 -
DVD to DV encoding quality
By olegpak in forum ffmpegX general discussionReplies: 4Last Post: 27th Dec 2007, 04:30
