Asus ms23
It's kinda hard to say unless you have the screen in front of you but the top one has some better specs and the bottom one has a DVI connector which is great for graphic cards now a days.
0.265mm vs. 0.266mm (the smaller the pixel the better)
10000000 :1 vs. 20000 :1 (the larger the number the more you can change you brightness I believe)
I know this probably didn't help much but as for the DVI I know you can get a connector that goes from HDMI to DVI so I would buy the one on the top. But always be sure to check for the customer reviews.. -
someone made a mistake and added a few zeros to the first one's contrast ratio. 10,000,000 is not even possible for an lcd. 10,000 is common. the second one has the better specs, 20,000 contrast with 300 brightness. cheaper after rebate too.
Yes it is. That monitor uses LED backlights. They simply turn off all the backlights to get the dark reading for a "dynamic" contrast ratio.Originally Posted by aedipuss
Manufacturers' reported contrast ratios are totally useless. In fact, most specs reported by manufacturers are useless, nothing more than marketing fluff. You have to see the monitors in question and/or find some independently produced specs.
http://www.extremetech.com/article2/0,2845,2349236,00.asp
http://www.extremetech.com/article2/0,2845,2356393,00.asp -
Indeed. You may be able to use them when comparing products within the same manufacturer line but then they're probably all going to be about the same then anyway.Originally Posted by jagabo
I would go for the LED LCD. I've really been enjoying mine and the color gamut on them (when you can get correct drivers for them) is a bit larger than the old CCFL counterpart. LED-LCD also draws less power and produces less heat than a regular LCD.FB-DIMM are the real cause of global warming
Playing 1080p video on a higher res monitor
By Long Hot Summer in forum Newbie / General discussionsReplies: 6Last Post: 8th Jan 2011, 04:25 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35 -
1080P Playback On My PC? And WD 1080p Player Need A Expert!
By wpittsen in forum Newbie / General discussionsReplies: 2Last Post: 30th Sep 2009, 12:43 -
HDV 1080p Im Looking for 1080p HDVs.
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 16th Nov 2008, 21:05 -
I'm stunned! Camcorder to 1080p monitor with HDMI!
By alegator in forum Newbie / General discussionsReplies: 10Last Post: 27th Jul 2008, 15:52
