  1. Are there any tools to convert between wmv (advanced profile) asf to a VC-1 elementary stream.
    I have tried ASF2VC1 with no luck because I keep getting a "Warning: replicatedlen=1; ignore" error.
  2. 1) haali muxer to wrap into mkv (you need your directshow filters in order, so install WMP11 and make sure your pins connect in graphstudio when rendering the .asf or .wmv)
    2) tsmuxer to extract .vc1 from the .mkv
    (mkvextract would normally be used, but it doesn't support vc1 in mkv)
    Certain types of audio won't work with this (only video)
