Hi all, I've tried to convert mkv videos to other formats like mp4 or avi. Most of the time it goes smoothly but sometimes i end up with a output video that plays faster than the audio. I tried using mediacoder and Any Video Converter. Mediacoder just stops converting at about 40%. Any Video Converter gives me the fast playing video. I think the problem is most likely to do with the video file. Is there a way the fix this? Thanks in advance for any help i can get.
Please post the details from the mkv, use mediainfo, open mkv, view->text and copy and paste here.
And I would also try latest handbrake or format factory. -
Here's the details from mediaInfo.Code:
Format : Matroska File size : 248 MiB Duration : 26mn 31s Overall bit rate : 1 307 Kbps Encoded date : UTC 2006-04-02 04:22:15 Writing application : mkvmerge v1.6.5 ('Watcher Of The Skies') built on Dec 7 2005 18:53:53 Writing library : libebml v0.7.6 + libmatroska v0.8.0 Video ID : 1 Format : MPEG-4 Visual Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 26mn 30s Bit rate : 1 153 Kbps Width : 640 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.125 Stream size : 218 MiB (88%) Language : Japanese Audio ID : 2 Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 26mn 31s Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 24.3 MiB (10%) Writing library : libVorbis 1.0.1 (UTC 2003-09-09) Language : Japanese Text ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English
Probably FPS or Vorbis are causing the issue.
Try Format Factory or Handbrake as suggested, and set FPS to default.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Issue with thumbnail creation for videos
By dchilkur in forum ffmpegX general discussionReplies: 1Last Post: 10th Mar 2012, 03:18 -
MKV Issue
By JCarnon in forum Video ConversionReplies: 7Last Post: 23rd Mar 2011, 13:33 -
Captured Videos Issue
By Equarter in forum Video ConversionReplies: 18Last Post: 19th May 2009, 19:43 -
MKV TO MKV issue
By cbrandon123 in forum Blu-ray RippingReplies: 19Last Post: 18th May 2009, 02:18
