Using Super to demux avi file.
Using AVI GUI to mux back into avi file.
Medianinfo says the original avi is divx video and mp3 audio.
Super demuxes to m4v and mp3. I'm trying to reencode audio then mux the AVI back together. It wont let me add the m4v stream file to AVI gui. I looked through the AVI GUI manual and it really doesnt say much about what video formats it will accept. Could someone tell me how to work around this to mux the files together using AVI GUI? Thanks in advance for any help!
Assuming that you mean AVI-Mux GUI;
1. Load the original avi file (video and audio) and the mp3 file in avi-mux.
2. Double-click on both files so they show up at the lower window.
3. Disable (uncheck) the audio of the avi file at the lower window.
4. Ensure that "all audio streams" on the gui is unchecked.
5. Press "start" and enter a filename for the output file.
You don't need to demux the avi first. -
Thanks for the info. Worked well once I did it your way!
Not sure why I couldn't interpret this from the manual...
Demux/Mux Tool
By mltwitz in forum DVD RippingReplies: 3Last Post: 7th Dec 2010, 10:39 -
Demux / mux .mov
By Evoks in forum MacReplies: 6Last Post: 11th May 2010, 13:19 -
Demux and Mux question
By danielmak in forum MacReplies: 1Last Post: 14th Feb 2010, 09:56 -
Mux/Demux Bug
By cefn in forum Video ConversionReplies: 3Last Post: 3rd Jun 2008, 13:09 -
Demux & Mux
By homantam in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2007, 08:51
