I have an old Al Jolson movie that is a Divx file. I put it in TMPGEnc Plus and lowered the bitrate enough to fit as a VCD on one 700MB CD-R.
But after it finishes it comes out to 900MB. I am using CBR at the moment.
What am I doing wrong? What can I do to remedy this?
I admit it has been a while since I have used TMPGEnc, but I never incurred a problem like this before.
Thanks for the help.
If everything is infinite then nothing is definite.
you can't adjust the bitrate of vcd mpeg-1. tempgenc is only fixing your error as it has to be 1150 kbps there is no other option.
Ok, but how come I can't make it fit on one disc?
If everything is infinite then nothing is definite. -
A fixed bitrate implies a fixed filesize for a given video.
At 1150kbps your video will occupy 900Mb.
900Mb is larger than your 700Mb disc. -
Burn the Divx file (if it's less than 700MB) directly to a CD and play it on your DVD player ( if you have a newer DVD player that supports AVI). Or if the Divx file is over 700MB, burn it directly to a DVD. Most newer DVD players will play this.
Or you can use something like DVDFlick to convert the Divx file to a DVD folder and then burn that to a DVD disk. Or, if you really need VCD format, first cut the Divx movie into 2 parts, convert each part to VCD and then burn 2 cds. All the VCD movies I have ever seen always come on 2 cd disks.
2-pass Parameters for x264 / BluRip
By nikemouse in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2010, 17:18 -
What's the best parameters for the OTHER settings in Ripbot?
By FTW in forum Blu-ray RippingReplies: 2Last Post: 21st Nov 2009, 12:08 -
Best xvid parameters for DV movies conversion
By Boro72 in forum Video ConversionReplies: 1Last Post: 18th Jan 2009, 08:47 -
MP4Box parameters for HTTP FastStart
By Wakewatcher in forum Video ConversionReplies: 0Last Post: 29th Dec 2008, 16:25 -
...setting webcam's parameters programmatically
By alexjep in forum ProgrammingReplies: 0Last Post: 12th Dec 2007, 11:36
