Hi,
I have recorded a wedding video with my JVC GZ-HD30 (setting: Full-HD, MPEG2) and want to convert the film to DVD-PAL (Germany). I use Sony Vegas 7.0e. Normally HD-Videos should be upper field first, and DVD lower field first.
There are two different settings in Vegas: one for the project and one for file output. I have tried different combinations of settings:
Project
1. uff, no deinterlacing
2. progressive, no deinterlacing
3. progressive, blend fields
Output:
1. uff
2. progressive.
In any of the combinations the motion of the video isn’t as smooth as the original (jaggies or “double” pictures). Do you have any idea, which setting delivers the best motion quality? It doesn’t matter, if the output file is interlaced or progressive.
Please excuse my poor English.
Kind regards
miepel
Results 1 to 14 of 14
project and output should stay interlaced tff if that's the way the source is. dvd format doesn't care if it's tff or bff, either one is fine.
Here is the Sheet of MediaInfofor one video file:
General
Complete name : F:\Hochzeit Micki und Fitschi 2009\Original\MOV00B.TOD
Format : BDAV
Format/Info : Blu-ray Video
File size : 165 MiB
Duration : 52s 29ms
Overall bit rate : 26.5 Mbps
Maximum Overall bit rate : 30.0 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, Matrix : Default
Duration : 51s 680ms
Bit rate mode : Variable
Bit rate : 25.1 Mbps
Nominal bit rate : 28.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.484
Stream size : 155 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Duration : 51s 816ms
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Video delay : -80ms
Stream size : 2.37 MiB (1%)
The original is 1920x1080i, the DVD schould be 720x576i. -
In theory, this interlaced resize should have worked properly, and it does in Vegas 9 according to tests I did for another project. Perhaps Vegas 7 is doing something differently?I have tried this setting (uff and no deinterlacing for project, uff for output), but the output showed jaggies. Perhaps there is an error in Vegas 7, but I guess it has something to do with the resolution change (1080i to 576i).
How are you examining the output? On a PC monitor and PC DVD player ? or on a standalone DVD player connected to TV ?
A standalone DVD player will deinterlace it properly and it should look fine, but a PC software player might not unless you instruct it to deinterlace on playback -
I have controlled the quality with my PC on a LG TFT and a Pioneer DVD Recorder, connected to my Toshiba LCD-TV.
So you put a burned DVD disc into the DVD Recorder for playback, and you still saw jaggies ?
Do you have another DVD player to test? It might be deinterlacing it poorly (but I doubt it)
I only started using Vegas when it was version 8, so I don't know if Vegas 7 had issues with interlaced resizing. Maybe some other folk know -
I put the files on a DVD and watched them with my Pioneer DVD Recorder on my Toshiba LCD (connected by Scart RGB) and my Yamaha DVD Player (connected by HDMI, no upscaling). The results were the same
Hi,
I think I have found the solution. With the following settings, the interlaced output file looks fine:
If you want to downsize a video with Vegas (e.g. 1920x1080i to 520x576i), you have to set your project to “field order: upper field first” and “deinterlacing: blend fields”, although you don’t want it to be deinterlaced. The output setting is “field order: upper field first”. It seems that Vegas “needs” this deinterlacing setting to downsize the video correctly. Here you can read the statement of another user, which agrees with me (please scroll a bit):
http://www.dvinfo.net/forum/what-happens-vegas/342018-field-order-hd-sd.html
Does anybody agree with these thoughts? Does it matter, whether the project setting is “blend fields” or “interpolate fields”? I could hardly see a difference and the file size is exactly the same. Remember, there is no deinterlacing at all.
Kind regards
miepel
PS: Please excuse my poor English again. -
hey if it works that's fine... when i need vegas to deinterlace i use it's interpolate fields setting, as i get better results from it.
for my own material i always shoot 1080 progressive and vegas has no problem making interlaced dvd mpeg-2 from it, or making youtube type online video from it.--
"deinterlacing: blend fields" will blur the two fields together leading to frames that look like blurry double exposures when there is a lot of motion and half the field/frame rate. That is one of the worst deinterlacing methods.
My guess is Vegas probably doesn't recognize your source is interlaced. Check the source properties and force it to interlaced if necessary.
field order wrong after AVStoDVD conversion
By 4evrplan in forum Authoring (DVD)Replies: 18Last Post: 26th Aug 2013, 15:59 -
Field order in NTSC DVD
By cheerful in forum Authoring (DVD)Replies: 1Last Post: 6th Mar 2010, 22:59 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Field order for PAL DVD
By PeskyJ in forum Authoring (DVD)Replies: 3Last Post: 29th Dec 2008, 20:59 -
Field Order When Converting HD source to DVD
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jan 2008, 01:22
