ok recently i bought some cheap dvd's, whenever i try to watch one it gets to a certain point then freezes, its unwatchable so i opened up the video_ts file and extracted all the files to a new folder, but when i try to convert them or burn to another disc i get errors. are there any programs or methods that can help me![]()
More information is needed, what are you playing it on, what are you burning it with, what error message do you get, what did you rip it with, do the vob files play properly when played individually. Meanwhile you might try creating an iso file and try burning that.
Clean the disk.
If still jams, get Isopuzzle.
It will copy the whole disk to an ISO file, retrying forever if necessary.
Then burn the ISO using ImgBurn, or Nero, etc.
If overnight ISOPuzzle still hasn't got 100%, then stop it and burn what you have. You may still have a glitch at that point, but the new disk will be readable to the player so it should keep going and recover. -
cheers, will POWERiso do the same job. Isopuzzle isnt working because my dvd player on my pc picks it up on my computer. but isopuzzle wont open due to there being no media in my dvd player
1st screenshot- of "my computer"
2nd screenshot- shows that its not detecting my drive
3rd screenshot- error message i get when i open ISOpuzzle
If you had read the help file, you would have seen:Originally Posted by 1ns0
The URL has changed, you can find it here:You need a working ASPI Layer on your system!
This program has been tested with the newest version of WNASPI32.DLL of
NERO AG (Version 2.0.1.74).
Please visit the homepage of NERO AG to get the DLL and read the terms
of use!
http://www.nero.com/nero6/eng/WNASPI32.DLL.html
Please put the WNASPI32.dll in the same folder as IsoPuzzle.exe - do not
copy it into your system folders. Please note, that the behaviour of this
program may depend on this dll.
ftp://ftp6.nero.com/wnaspi32.dll
And please don't send PMs about this kind of question, that's what the forum is for.
Problem VOB-DV
By crisssi in forum ffmpegX general discussionReplies: 4Last Post: 20th Feb 2010, 03:33 -
vob to avi using alltoavi (problem)
By anlaoch in forum Video ConversionReplies: 5Last Post: 22nd May 2008, 17:54 -
vob files problem
By warlock110 in forum Newbie / General discussionsReplies: 6Last Post: 23rd Mar 2008, 11:32 -
Problem with Vob files
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2007, 10:04 -
Problem with .VOB to .MPG
By SilverFalcon in forum Video ConversionReplies: 2Last Post: 30th Jul 2007, 13:27
