are there any programs to convert mkv to another file format to use for nero like mpeg-2 perhaps?
i use tsMUXERgui but the problem is a lot of times the video is out of sync or choppy or something else bad. the worst is the volume is turned down a half at least 50% from the original audio which is much louder.
Is there a way to fix this? Any better recommendations for converting/encoding mkv to another file?
FAVC, DVDFlick, AVS2DVD, or, if you'd rather have Divx/Xvid, then AVIDemux or VirtualdubMod.
Volunteer for https://www.computersforkids.org.uk/
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 10:03 -
BD backup file storage: which format? H.264, .mkv, .m2ts,
By jlm86 in forum Blu-ray RippingReplies: 6Last Post: 21st Feb 2011, 15:27 -
How to convert mkv to ps3 viewable format maintaining mkv subs in new file?
By shuyinliquid in forum Video ConversionReplies: 2Last Post: 14th Dec 2009, 02:17 -
Nero Vision TSmuxergui converting MKV files
By vieya in forum Video ConversionReplies: 1Last Post: 30th Nov 2009, 12:47 -
Converting MKV file to DVD burnable format
By ryoden in forum Video ConversionReplies: 6Last Post: 29th Jul 2008, 14:54
