  1. I want to convert to VCDs? Don't know for sure whether to use Forced Film, 64-bit Float, PC/TV, etc. Thanks.
    Jeremy
    Jul 2001
    One Step From Hell
    Here's the rule of thumb I use:
    The next step is finding out what kind of movie we're dealing with. First of all select Video - Field Operation and set it to None. Then F5 to start the preview. Let it run for a bit and watch the status window.
    Frame Rate = 29.970 fps: Let the preview run for a couple of minutes, then take a look at the Video Type: If it's FILM at a percentage higher or equal to 95% you can activate Forced FILM as shown below.
    As far as sound goes I pick......Track number/NONE.
    I then rip the audio from the VOBs using Microsoft Graph Editor.
    I got this info from a guide @ the Doom9 site. http://www.doom9.org/mpg/tmpg-main.htm
    Hope this helps
  3. Is there a reason why you let the Microsoft Graphedit do the audio ripping rather than letting DVD2AVI do it by selecting Track 1?
  4. Personally I always let DVD2AVI grab track 1 audio, and never had a problem.
    Jul 2001
    One Step From Hell
    I do it that way do to the fact that the guide I use says that dvd2avi doesnt handle audio very well and i tend to agree. When I use Graphedit the audio sounds alot better and the volume is ALOT higher(Dont have to turn my TV up as loud)
    Thats why!!!!!
  6. yeah... its like lame and tmpgenc.. if your an extreme audiopile you may notice the difference. i run my sound at 96 kbps so i try not to involve extra apps... i cant tell the difference even at 224 kbps. go ahead and use dvd2avi's audio decoder.
