What is this piece of hardware intended for? Encoding? Sound production? Gaming?
I'm aware there is system performance improvements, but what is the main technical use for this hardware?
What sort of cool things can you do with it?![]()
(Does this interact well with premiere CS4?)
Creative Sound Blaster X-Fi Titanium Fatal1ty Champion Series 70SB088600007 7.1 Channels PCI Express x1
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102021
makes games sound better.
Sort of. It's mostly marketing gimmick since most any Soundblaster X-Fi use identical EAX decoders but the idea is it offloads the audio decoding work from your system to the card when EAX is used (which is present in almost every game these days it seems). Usually these extended options are unavailable until you have a card with EAX. EAX has a lot of neat things when gaming in surround like precise sound panning and the like. I don't think any of the Adobe apps use EAX so I don't think you'll see much of a difference there unless you have a really poor audio component to your PC. Any onboard HD audio component should suffice for Soundbooth.Originally Posted by aedipuss
That specific version also has some additional input/outputs and features if you want to control your audio separate from the system (it has a remote control, doesn't it?). It isn't a bad sound card underneath all the marketing fluff but you can get away with cheaper for the same performance, unless you want all those additional features.FB-DIMM are the real cause of global warming -
With the right speaker config or descrete suround sound headphones they are good for hearing someone sneaking up behind you in game
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html
Sharp XA-series "Professional" VCR's ... any good?
By jbd5010 in forum Capturing and VCRReplies: 1Last Post: 15th Apr 2023, 21:52 -
Mini DV + S-VHS Combo Decks: "SR" Pro Series vs "HR" Consumer Series
By jbd5010 in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2011, 23:34 -
Sound Blaster Titanium Fatal1ty Pro
By MR 3 in forum AudioReplies: 2Last Post: 16th Sep 2010, 12:49 -
Filtering the cult series "Invader ZIM" using Avisynth
By rm2kpro in forum Video ConversionReplies: 6Last Post: 24th Jul 2010, 22:10 -
NBXSOFT and "Free" series ?
By bilm in forum Newbie / General discussionsReplies: 1Last Post: 22nd Mar 2008, 05:33
