I keep getting an error message from convertx2dvd. Never had a problem using this or the youtube downloader to convert flv files - until about six months ago.
Now using an updated version of youtube download manager and it saves a flv double in size compared to the one in the browsers cache. Why is that? No errors using these programs now but it's the thought of the flv file being converted again prior you know? Hate this extra step.
What error message are you getting from ConvertX2DVD? (I don't use it, myself, so I probably won't be of as much help.)
As for the 'double-size' FLVs, the downloader probably defaults to saving the "higher quality" versions of the videos as opposed to the 'normal' versions. (Those would be a better version to get, anyway, if you are indeed looking to convert them for DVD.)If cameras add ten pounds, why would people want to eat them? -
Originally Posted by Ai Haibara
Hi,
Here's an example from convertx2dvd error log:
12/14/2009 10:07:27 PM warning File "C:\Faith No More @ Pukkelpop Patton embarrasses VIP's.flv" ignored. Unrecoverable error while reading.
I think when a flv video file is 16x9 it causes this problem. Installed the ffdshow codec but still get the error message if it tries to open an flv copied from my opera browser cache. -
Try giving the file a short 8:3 filename (eight letters, plus the . and three-character extension), without spaces or the @ symbol - just letters (and numbers, if you prefer), and see if ConvertX2DVD has any problems reading the file, then.
If that doesn't work, try running the file through a utility like MediaInfo, using Tree View, and copy and paste the resulting information here.If cameras add ten pounds, why would people want to eat them? -
Hi and thanks again for helping, Ai Haibara.
I renamed the original file to eight characters as flashtest.flv and it still would not open in convertx2dvd. Also I was wrong about the 16x9 thing, this video was 4x3.
Here is the text log of the renamed file and the same vid downloaded with youtube downloader. This time YD saved a file smaller than the one from cache, 18mb vs 24mb.
General
Complete name : C:\flashtest.flv
Format : Flash Video
File size : 24.9 MiB
Duration : 4mn 21s
Overall bit rate : 799 Kbps
Video
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Container profile=Unknown@3.0
Duration : 4mn 21s
Bit rate : 727 Kbps
Width : 480 pixels
Height : 360 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.140
Stream size : 22.7 MiB (91%)
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Duration : 4mn 21s
Bit rate : 64.3 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 2.01 MiB (8%)
General
Complete name : C:\YouTube- Faith No More @ Pukkelpop Patton embarrasses VIP's.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 18.9 MiB
Duration : 4mn 21s
Overall bit rate : 606 Kbps
Encoded date : UTC 2009-08-20 03:39:27
Tagged date : UTC 2009-08-20 03:39:27
gsst : 0
gstd : 261803
gssd : BD075F885MH
Video
Format : AVC
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 4mn 21s
Bit rate mode : Variable
Bit rate : 540 Kbps
Maximum bit rate : 1 074 Kbps
Width : 480 pixels
Height : 360 pixels
Frame rate mode : Constant
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.104
Stream size : 16.8 MiB (89%)
Title : (C) 2007 Google Inc. v08.13.2007.
Tagged date : UTC 2009-08-20 03:39:29
Audio
Format : AAC
Format/Info : Advanced Audio Codec -
Originally Posted by tom z
I don't know anything about ConvertXtoDVD, but perhaps it doesn't support this combination (or maybe the latest one does and you have an older version).
Your MediaInfo data also suggests that could be the problem - the file that works is an mp4 container, not flv.
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39 -
Can I convert DVD copied to HD into a MKV file?
By nzdreamer55 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Nov 2010, 17:43 -
blu-ray plays flv file?
By andregps in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jan 2010, 21:27 -
stand-alone DVD player that plays both rmvb and flv files?
By spiffy in forum DVD & Blu-ray PlayersReplies: 3Last Post: 4th Dec 2009, 01:46 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14
