I have a bunch of avi files among many from supposedly the same encoder that won't play in anything but VLC. Gspot doesn't even detect them and I can't open them in anything else including virtualdub. Are these corrupted? There doesn't appear to be any kind of reduction in file sizes compared to the ones that can actually play. When I do play them in VLC they run perfectly, but I get a "can't render file" message when I use media player classic. Can these be "repaired"?
Video
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Width : 576 pixels
Height : 432 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Writing library : XviD 1.1.2 (UTC 2006-11-01) -
Try renaming the .extention part, to something like .mp4 and see if that does anything..it has worked for me on some cases.
I usually put a shortcut to KMplayer on my desktop..then I open a folder and just drag files that I want to play or am testing playback issues on. I usually have side-by-side, with VLC to. Sometimes opening up a file inside the player is not as effecient.
If anything, you may have to demux the video into separate video/audio parts and then remux back into another/new container..maybe .mkv or something. Give MP4box a go, it seems to be one of the most common tools thrown around for this sort of stuff, I think.
-vhelp 5277
:P *~*!*~*!~* HaPpY HoLiDaYs *~*!*~*!~*
Install xvid.Originally Posted by jagaboI think,therefore i am a hamster.
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 08:40 -
PS3 won't play some MP4 and AVI files
By jiggy in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Feb 2010, 20:22 -
Samsung HD video won't play in VLC, but will in Win 7 WMP... why?
By wild_fan in forum Software PlayingReplies: 3Last Post: 18th Dec 2009, 13:33 -
subtitles in VLC won't play
By petliura in forum SubtitleReplies: 1Last Post: 10th Dec 2008, 09:16 -
Demuxing Smartripped VOB with VobEdit06... M2V won't play in VLC?
By Iceblade in forum Video ConversionReplies: 12Last Post: 15th Oct 2007, 23:30
