I just bought a Canon Vixia HF 200.
I'd think progressive is better than interlaced. Is that true?
Which frame rate should I use? 24 or 30? 24 seems to give each frame more bits. But most display are 60 Hz, matches 30p not 24p. 120p display is quite expensive right now.
Thanks!
what camcorder? and what is the final playback format going to be? dvd, blu-ray, youtube?
Canon Vixia HF 200, FXP, 17 Mbps.
The playback is intended to be on bluray. Would also want to create DVD for grandpa.
Thanks -
for most things shooting in 60i would be best. keeping it interlaced for dvd makes things easier and it's fine for blu-ray. i'd shoot 30p if you were going to put all the vids online. 24p is not really useful, too slow for normal activity.
I just learned that Bluray does not support 30p directly. It's treated as 60i. I'd think it plays fine, right? Premiere does not have a template for it but it should not be hard to come up with a custom one.
My guess is that for moving subject, 60i would be smoother since the framerate is twice as high. Is it right?
Thanks! -
60i for hand held.
30p for streaming
https://forum.videohelp.com/topic373851.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Both are jerky in pan/tilt.
1080i is being converted to 30p by Youtube?Recommends: Kiva.org - Loans that change lives.
Authoring HD/720p to SD-DVD: Render to 24p or 60i?
By mltwitz in forum Authoring (DVD)Replies: 15Last Post: 29th Nov 2011, 01:52 -
60i to 30p without re-encoding?
By bobthegoat2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 38Last Post: 30th Sep 2011, 09:55 -
Help explaining 60i (30p sensor output)
By x2x3x2 in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2011, 22:05 -
Quick question on Deinterlacing 30P in 60i containers
By ayim in forum Video ConversionReplies: 5Last Post: 30th Dec 2009, 22:06 -
frame rates 24 30 30p 30i 60 60p 60i
By maxtrack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 28th Jul 2007, 17:21
