I have a video that plays on my PS3, but no audio output. I have seen this with vbr audio which I fix with VirtualDub. I have tried everything to correct this video, but I end up with the audio out of sync with the video. I think the problem is the bit rate: 40.0 Kbps, but bumping it to 128 creates an out of sync problem. Any help would be appreciated.
Here are the specs for the original video:
Video
Format : MPEG-4 Visual
Format profile : AdvancedSimple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 56mn
Bit rate : 1 561 Kbps
Width : 704 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.292
Stream size : 1.27 GiB (97%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 56mn
Bit rate : 40.0 Kbps
Channel(s) : 2 channels
Sampling rate : 24.0 KHz
Stream size : 33.2 MiB (2%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Thanks for the suggestion which I tried. The problem with AviDemux and VirtualDub is resampling causes the audio to run in advance of the video which I can compensate for. But in this case, the audio goes out of sync again latter in the file. This is my first encounter with a video file I could not fix. Any other ideas?Originally Posted by t0nee1
1080p Video Plays On PS3 With Audio Only
By Startropic1 in forum Video ConversionReplies: 7Last Post: 22nd Feb 2012, 12:21 -
My PS3 plays my AVCHD video well.
By jbitakis in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Jan 2012, 14:04 -
movie plays right on pc,but faster in my ps3 help
By boltmccrash in forum Blu-ray RippingReplies: 0Last Post: 19th Oct 2010, 10:06 -
Help with Authoring BD-R Video that plays on Playstation 3 PS3
By robbalvey in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Apr 2010, 06:54 -
PS3 video and audio
By efiste2 in forum Media Center PC / MediaCentersReplies: 10Last Post: 14th Jul 2007, 19:05
