I am having trouble converting an xvid avi file to mpeg-2 so that I can write to a DVD using Sony Vegas. I am using MediaCoder but the quality of the video is terrible and the audio is not synchronized with the audio. I am somewhat nesw to video converting. Should I be using certain settings to do the conversion? What are the ideal settings for converting?
MediaCoder gives me options:
Mode: bitrate based, quaility based, two pass, or three pass
Kbps
Frame Rate
Any help is greatly appreciated
I guess you have problem importing the xvid in vegas? Be sure to install the xvid codec.
And if you don't need any editing just use an all-in-one free dvd converter like dvdflick, avstodvd, etc. -
if u install xvid codec, i think u can import directly avi xvid to sony vegas to convert mpeg-2.
Sometimes the streams get lost in codec translation, when the audio is at fault I recode the audio using virtualdub and if the video is having issues I use fourcc to set the video codec as "divx" and that usually solves it.
Converting Xvid AVI to DVD
By rocks911 in forum Video ConversionReplies: 2Last Post: 21st Aug 2011, 19:24 -
Problem with Mp4cam2avi converting to XviD AVI
By twister6 in forum Video ConversionReplies: 11Last Post: 25th Jun 2010, 01:09 -
Converting DV AVI to xVid AVI (with AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 6Last Post: 5th Jul 2007, 00:56 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 09:57
