  1. Didnt know where else to post this since I have no idea what it is called. I want to take two mpeg2 videos and combine the two together. I dont mean end to end, but take a music video and an action video and mesh the two together. Have the two fade in and out of each other but the music never stops. I have seen them on Youtube but have no idea how to make one. I have TMPGE Authoring Works 4 but the only thing I can find is how to transition from one clip to the next. Any help appreciated.
  2. You put two videos on the timeline, cut them were you want crossfades, then add crossfades to the cuts.
  3. You also split the audio off the music video and drop it on the audio timeline, then mute the video tracks.
    WMM can do this as well as others.
  4. OK I think I know what you are talking about. De-mux the audio from the music video then cut the two into several small videos and then mix them back together? OK I will give it a try and see if I can make it work. Thank you both for the help.
