    Dec 2009
    Australia
    I have video that I want to DeShake (the movie is from a DLSR canon 500d). I have used the deshaker plugin for virtualdub before and it did a good job.
    Gspot says the video is .MOV (quicktime)
    Codec = avc1 Name = h.264
    Codec status is undetermined.
    I cant seem to get a combination of plugins that will open the file, decode and deshake it under virtualdub.
    Would anyone be able to tell me the specif plugins I would need to accomplish this? (is it possible?)
    Cheers
    Apr 2004
    Miskatonic U
    I believe there is a quicktime plugin for virtualdub, although I would repackage the video and audio into an MP4 container, then use a simple avisynth script to allow vdub to work with the file.
    DirectShowSource("pathtovideo/video.mp4")
    would be enough
    Read my blog here.
    Jul 2009
    Spain
    You can get a set of input plugins for VirtualDub here:
    https://www.videohelp.com/download/VirtualdubPluginPack.zip
    This includes both a Quicktime and a DirectShow source plugin, which are suitable candidates for your file.
    Using the DirectShow plugin is equivalent (and hence an alternative) to using a script with DirectShowSource.
  4. I find the default setting of the Quicktime plugin often doesn't work. Try switching to the different Video Decoder Modes using the Extended Options dialog.
    Dec 2009
    Australia
    OK, I have downloaded https://www.videohelp.com/download/VirtualdubPluginPack.zip and unpack into the appropriate directory.
    I try to open the video in question and same result - black screen.
    I try to select the extended options in the open file dialog but no dialog appears after opening. (If I select extended options on an AVI that I know works in virtualdub then the dialog comes up as expected). Does anyone know why this might be the case - can others get the extended options dialog to work on MOV files?
    This video plays in VLC so I know that the file does contain video, I just cant convince virtualdub to let me see the video.
  6. Member MJ Peg's Avatar
    Dec 2008
    I just managed to load an SX1 mov file into V.Dub using an AviSynth script as follows :
    sx1_test.avs
    FFMpegSource2("C:\Users\me\Downloads\86619157_orig_SX1.mov",atrack=-1)
    DelayAudio(1.0)
    (The audio delay compensates for the 30 frames mess-up that deshaking introduces)
    To get the FFMpegSource2 command working, install the package from code.google.com/p/ffmpegsource/
  7. Originally Posted by gazza67
    Try forcing the Quicktime reader in the "Files of Type" pulldown of the Open Video File dialog.
