I have a video that is a divx/avi file. The aspect ratio is 2.35:1. When I try to convert to DVD using ConvertX to DVD or Cyberlink Power Producer it changes the aspect ratio on the DVD that I create. How can I keep the same aspect ratio? Is there a better conversion software?
Thanks,
Dwpoze
It has to change it so it'll play back at the correct aspect ratio. Are you saying when playing the DVD the AR is off? If so, I'm not sure I believe that. Or are you looking at the unresized 720x480 video? Yes, people are too tall and thin, but when played as a DVD they get 'normal' again. Every AVI to DVD converter does the same thing.Originally Posted by dwpoze
What the software should be doing (assuming no borders in your source) is resizing the source to about 720x360, adding 60 lines to the top or the frame, 60 lines to the bottom (enough to bring the frame up to 720x480), then encoding as 16:9 DVD.
Changing pixel aspect ratio of video clip?
By Real Ramona in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jan 2012, 11:20 -
Changing aspect ratio of video files in iso so for burning w/ correct a/r
By cinesimon in forum Authoring (DVD)Replies: 6Last Post: 10th May 2011, 03:40 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 19:18 -
changing aspect ratio of home video before burning
By bec in forum Authoring (DVD)Replies: 3Last Post: 8th Jul 2008, 13:54 -
Changing aspect ratio (reauthoring DVD)
By Turbo Sensonic in forum Authoring (DVD)Replies: 38Last Post: 12th Aug 2007, 19:17
